Speedo With Gear Change.... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 11-17-2012, 07:44 PM Thread Starter
jnor's Avatar
When I changed the sprockets on my Vee to 16/43, the speedo was way fast...(i knew it would be)..
I just put a speedodrd from 12oclock labs on it last night, and used my GPS speed to calibrate it...It's now perfect.. Easy install, great product...
SpeedoDRD
05 FJR
jnor is offline
post #2 of 21 Old 11-18-2012, 12:27 AM
Did the same, very easy to do with great results.
hansong is offline
post #3 of 21 Old 11-18-2012, 12:30 AM
bwringer's Avatar
Me three!
The Speedo DRD is smaller and less expensive than the Speedo Healer. Mine has been flawless -- I think I've had it more than a year.
bwringer is offline
post #4 of 21 Old 11-18-2012, 06:52 AM
x4 on the SpeedoDRD!
DL1000K7
jayDL is offline
post #5 of 21 Old 11-18-2012, 07:08 AM
Hi
I have a couple questions...
What is the install process on this unit?
Using my gps, I have found my speedo to be fairly accurate up to about 45 mph. From there up it reads slow and around 60 actual it reads 55. If I install this and set the adjustment at 60 as it says to, will it throw off the speedo below 45 where it is about right?
Mark
Nyparrothead is offline
post #6 of 21 Old 11-18-2012, 07:59 AM
Banned
Originally Posted by jnor View Post
I just put a speedodrd from 12oclock labs on it last night, and used my GPS speed to calibrate it...]
it fixes the speed-o. how about the ODO and trip 1, trip 2 meter?
JRWalker is offline
post #7 of 21 Old 11-18-2012, 09:36 AM Thread Starter
jnor's Avatar
That also...
05 FJR
jnor is offline
post #8 of 21 Old 11-18-2012, 10:26 AM
Moderator++
It depends on what you mean by fix. The speedo is ~8% high in stock condition while the odo is ~2% high. Doing a fix for gearing won't change that relationship as the two can't be adjusted separately.
greywolf is online now
post #9 of 21 Old 11-18-2012, 09:50 PM
bwringer's Avatar
The Speedo DRD and the Speedo Healer both do the same thing -- they simply intercept the signals coming from the speedo sensor and send out signals that are whatever percentage you set faster or slower.
It's a simple percentage alteration -- speedos are normally off by a certain percentage.
The correction widgets come with instructions for calculating the correction needed, and there's even a calculator on the maker's web sites. The easiest way by far is to go for a ride with a GPS installed and note the differences in the readings.
bwringer is offline
post #10 of 21 Old 11-19-2012, 05:23 AM
My speedo is actually very close to accurate under 45mph.. But by 55 -60 it is 5 mph slow
Mark
Human Verification
