Speedo With Gear Change.... - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 21 Old 11-21-2012, 07:19 AM
Originally Posted by Nyparrothead View Post
Hi
I have a couple questions...
What is the install process on this unit?
Using my gps, I have found my speedo to be fairly accurate up to about 45 mph. From there up it reads slow and around 60 actual it reads 55. If I install this and set the adjustment at 60 as it says to, will it throw off the speedo below 45 where it is about right?
Mark
Anyone have an idea?
Nyparrothead is offline
post #12 of 21 Old 11-21-2012, 09:15 AM
Moderator++
The speedo is about 8% optimistic. That's how percentages work. The lower the speed the lower the error. Dial in the 8% for stock gearing or the proper amount for altered gearing and it will be fixed across the board. Of course the odometer will read a bit low after that because it is only 2% high in stock condition.
greywolf is online now
post #13 of 21 Old 05-19-2013, 02:10 PM
How do you install speedoDRD? Do you need to pull the fuel tank off? I just wen to 16/43 gearing
Thanks,
Jeff
'12 DL1000
jmackd1 is offline
post #14 of 21 Old 05-19-2013, 02:19 PM
Moderator++
Find the connector from the speedo sensor. Chances are it is accessible from the left side of the bike. That connector is separated and the speedoDRD has two connections that plug right in to the two halves of that separated stock connector.
post #15 of 21 Old 05-19-2013, 04:15 PM
HeUeR's Avatar
Thanks,
Jeff
'12 DL1000
I found my connector at or near the front of the idle adj tucked in up there (Left side) without taking anything off. I ran the unit to in front of the battery and zip tied it there. Easy easy install...but I had to read the instruction book a few times to comprehend how to program it. I just switch (8.4% correction) back to stock gearing today from 17/42s (10% correction) because 90% of my daily ride is on a Interstate. Well worth the money.
https://www.youtube.com/watch?v=EeB5ZraUeYQ
HeUeR is offline
post #16 of 21 Old 05-20-2013, 05:59 PM
ted
ted's Avatar
Countershaft nut size
Can anyone please confirm that the transmission sprocket nut is 31mm on a Vstrom 1000
ted is offline
post #17 of 21 Old 05-20-2013, 06:03 PM
Been a few months.......90% sure it is a 30mm.
See below.......cleared up by the boss.
Black Rhino is offline
post #18 of 21 Old 05-20-2013, 06:26 PM
Moderator++
It's 32mm or 1-1/4" and I'm positive.
post #19 of 21 Old 05-21-2013, 02:25 PM
found it, it was right where you said.....Thank you....
Jeff
'12 DL1000
Austin, TX
jmackd1 is offline
post #20 of 21 Old 05-22-2013, 02:17 AM
ozart's Avatar
My speedo is actually very close to accurate under 45mph.. But by 55 -60 it is 5 mph slow
Mark
I'm interested in the gearing you have that makes your speedometer read slow.
ozart is offline
Human Verification
