DL1000 Chain Question (ordering question) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-15-2012, 04:28 PM Thread Starter
shawnubis's Avatar
After a couple of hours scouring through the opinions of many, I'm about to order the DL1000 530 Chain and Sprocket Combination from SVRacing.
My question is, do I need to get the extra master links offered, and if so, which one? The clip on, the rivit on, or the screw on??? Most say it can save you in a jam to have the spare, but then...what special tool would I need to save my own arse should said spare be utilized?
Im new to chains and somewhat new to the forums. I truly appreciate your help/input.
Thanks
If you think you don't need a helmet, you probably don't.
And remember kids, Safety Third!
shawnubis is offline
post #2 of 6 Old 11-15-2012, 04:43 PM
Scott E. Bonds's Avatar
I ordered the 525 stock chain set up with stock ratio sprockets. I prefer the press rivet set up so I ordered that type master link and bought 2. That way I had a spare if I screwed up on attempt 1 to rivet. Now that I am ready to replace my setup again, I have a spare master since the rivet process went just fine last time around.
So, if its your first try I would buy 2 master links. As for carrying a spare on the bike, you would need the rivet tool also. I have never had a rivet fail or the need to replace a chain on the road. My spare stays in the home tool box. You do realize the rivet type chain takes a special installation tool to break the old chain and rivet the new master link. Its an easy process if you watch the little parts and read the instructions.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #3 of 6 Old 11-15-2012, 04:56 PM Thread Starter
shawnubis's Avatar
Thanks Scott. Torn between the 530 or the 525, both come with one rivit master link, so I'm going with ordering one extra. I got 30k out of my stock chain & sprockets. Not sure how or why. Wondering if it's worth the $40 for the 530 setup. I'm doubting it. I must have gotten lucky with the stock chain & sprockets. The sprockets still look fine, but I know the chain is ready for replacement.
As for installation, I'm too busy to deal with it right now. It's going into the local Ducati shop here in Pensacola. I hear nothing but solid things about them, and they service everything. They'll do the chain too. It'll cost me $100 for them to install it; it'll cost me $100 for the tool, plus time I don't have right now (plus -20 points for cursing, I'm sure). Thanks for your input.
post #4 of 6 Old 11-15-2012, 07:06 PM
Some more info. The Vee gets a lot of buildup around the counter sprocket area under the cover from chain lube. Your push rod for the hydraulic clutch goes through there also. If the Ducati guy pulls the cover and cleans and inspects everything properly, than the price is a bargain as it takes an hour or two. I assume he will since you are changing sprockets.
The 530 is stronger but may not last any longer. The hp output of a vee is around 100 so the 525 is plenty strong. The stock set up wears very well so do not expect much if any extra from the SV version...which I also purchased myself in 525.
Your choice, but I figured the 525 did fine, so did replacement number 1. All went about 30,000 miles with only quality chain lube and no chain cleaning at all.
Good luck.
P.S. - by stock I meant OEM size and ratio. My second set were steel of some unknown/forgotten brand, my last set came from SV also, good service, good product, and a forum brother.
post #5 of 6 Old 11-16-2012, 10:13 AM
Craig Jackman's Avatar
Don't forget to change the rubbers in the cush drive hub. Mine were so worn you could wiggle the sprocket back and forth in place which probably did nothing for chain life. You will also want to check the sprocket carrier bearing, probably replacing it and the dust seal.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #6 of 6 Old 11-16-2012, 10:31 AM
If you intend to own this bike for the full life of the new chain, the 530 will live longer and save you money.
Good advice from the postings above about cleaning and checking the rubber dampers and carrier bearing. I clean around the front sprocket every oil change. It only takes a few minutes, keeping things clean is always good, and it is a good chance to take a look at potential trouble spots before they leave me stranded. I'm already dirty and have tools out, so it is little extra work. (Deep 8mm socket on an extension is the only extra tool I need on my Wee for the cover and a 10 mm for the Wee clutch helix gizmo if I clean that.)
Many of us are comfortable telling the truth and uncomfortable lying.
An ordinary liar lies to gain an advantage.
A pathological liar knows that you know he's lying, and he lies to you anyway. Lying is comforting. Truth telling may be difficult and uncomfortable.
Human Verification
