K3 Vee Stator magnets - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #31 of 42 Old 11-29-2012, 12:24 PM
Banned
I think the coils are wired so they repeat in sequences of 3 so a void will have a uniform pattern as it goes around.
Maybe we need 3 AC meters
I am/will become familiar with how my Signal Dynamics LED works normally and hope I will notice a change in behavior. I also will use it to see if the battery takes looong to recover
Come the spring I will be treating myself to a fresh Yuasa the biggest that will fir under the seat
richw is offline
post #32 of 42 Old 11-29-2012, 11:30 PM
LoneStrom's Avatar
I have a Shorei ?? Batt in my wifes GS500,pretty amazing batt.It can sit for 9-12 months and still be at full charge.It came in the bike,I don't think I would spend the $$$ on one myself.
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
LoneStrom is offline
post #33 of 42 Old 11-30-2012, 01:35 PM
epoxy
jb weld is ok but if you really want somthing to stay put go to a diesel fuel injection repair shop and get some Stanadyne epoxy part # 15386 it is on the pricy side but it will hold clean the surface good first with a good brake clean and scuff with sand paper godd luck
DDBURGMAN is offline
post #34 of 42 Old 01-17-2013, 03:15 AM
Had bad experience with the magnets! One thing led to another...firstly, the bike broke down at Malaysia/Thailand border in October 2012..thought it was the battery..jump start and it worked for just a while..then it went dead again..forced push start the bike and worked for about 100kms and totally stalled when fuelling up at the gas station..finally decided to tow the bike to Krabi, Thailand as that was my destiny for a Tri-Nation Ride..Bought a new battery. Lasted only 5 minutes and totally drained out..Mechanic thought it was the rectifier problem and managed to find one and replaced it..That was not the case either! The Thai mechanic suggested to open up the stator casing but i refused b'coz worried they might not have the parts available and i hv to travell all the way to Thailand again to claim the bike..Finally towed back to Malaysia and open it up and found the magnets have fallen off (3 pieces) and slightly damaged the stator..Ordered the new magnets (looks like one big metal bowl) and really have no confidence looking at the way the magnets were sticked to the casing..just a thin line of adhesive! Bought this new and it wasn't cheap! Recoiled the stator and way i go! After 200kms, the EFI blinked and few minutes later the engine just died while I was speeding @ 150kmph! dropped gear and it came back to life but on hesitation..and finally engine on a total stop and lucky enough i managed to reached a gas station along the highway..towed back to workshop and open up the stator just to find out that it was totally toasted! Ordered and replace a new stator (now i got the full new set of magnets and stator = MAGNETO) but a new problem arised..surging at low rpm..did all the necessary TBS,TPS,Injectors cleaned but the bike seems to hesitate at low rpm and when temp reading @ 3-4bars)..tested the ECU and was told it could be the main reason for surging..1 injector works but the other doesn't..switched injectors position, same result..ok, so i ordered the ECU and it ain't CHEAP @ MYR5.3K = USD1.3K! Well, waited for a month and only to know that my ECU is not available in Japan as my bike is a European spec..What the heck?? Finally, made my online purchase from a recycle dealer in UK and got the unit in a week's time! That was fast! Tested it, and was told by the mechanic, the ECU worked fine and that has put my nightmare away for good for the time being! Don't know how long i'm gonna keep this bike, but surely i'll get rid of it before the next magnets comes off! I only done 36K kms on the ODO b4 all this mishaps happened! One pc of advice, Please do not force start your bike like i did on few occassions if it stalls, as it would or could somehow or rather cause damage to the ECU! I've spent too much $$ on this bike and am not prepared to spend more in future!
xyberguy is offline
post #35 of 42 Old 10-17-2013, 09:27 PM
I remember seeing 4 magnets in the rotor of my 02, is that right? Seems everyone is talking about 6 magnets...
gaps is offline
post #36 of 42 Old 10-17-2013, 09:32 PM
Moderator++
This is a typical loose magnets sliding together scenario.
They should look more like this.
post #37 of 42 Old 10-17-2013, 09:44 PM
OK, not going crazy, microfiche shows 4 magnets for 2002. I'm hoping the larger surface area will keep the somebitches in place...still stuck there at 47k miles.
gaps is offline
post #38 of 42 Old 10-17-2013, 11:49 PM
Moderator++
The 2002 Vees were the only ones with 350W alternators. The rest have 400s.
post #39 of 42 Old 10-18-2013, 10:35 AM
The 2002-2003 Vees were the only ones with 350W alternators. The rest have 400s.
Not positive, but think the '02 Vee was the one with the 350 watt output. '03 went to 400 watts. '03's have 6 magnets for sure.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #40 of 42 Old 10-18-2013, 10:51 AM
Moderator++
That's right. It changed in 2003. I'll change it.
Human Verification
