automatic chain lubrication - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 43 Old 10-23-2012, 01:48 AM Thread Starter
im thinking about installing en esystem from scotteroil but i wonder, if the oil hits the chain only at one side, how does it flow to the othet side?
even if it does, the rings from bought sides will never get even lubrication
am i right or am i right?
iyaronman is offline
post #2 of 43 Old 10-23-2012, 02:10 AM
I use a simpler manual oiler and ATF, no problems there, it hits the chain then works it's way around without me making any effort. If nothing else it gets smeared over the teeth on the sprockets and transfers that way.
It's not the 'lube' on the chain that does the magic as the rollers are internally lubed and sealed, what wins seems to be a combination of these factors:
- Stopping the chain from getting rusty
- Keeping the o-rings 'wet' so they don't catch on the side plates and tear
- Slowing the wear from the grinding action between chain rollers and sprockets.
Pete
PeteW is offline
post #3 of 43 Old 10-23-2012, 09:42 AM Thread Starter
10x for the info,
by how much you estimate increasing chain life?
post #4 of 43 Old 10-23-2012, 10:08 AM
Scottoiler
This is my first full season after installing the Scottoiler. It is a vacuum actuated unit. I use ATF. After 20,000 klms, 2000 offroad, I am a believer. My chain remains in excellent shape and I have experienced none of the power-robbing friction scenarios (dry chain). It is set on the absolute lowest setting (it doesn't take Much).
dilrod is offline
post #5 of 43 Old 10-23-2012, 05:42 PM
You can buy an oiler that has a split system and does both sides. Otherwise, you can buy the hose and put in your own split system using tubing and two nossles. You can get the tubing at pet shops as its the same as the air line they use and very cheap plus they have all of the little fittings, also at a cheap price.
2008 DL1000 - Two Bros cans, ProTaper Bar, Oxford Grips, PC111, Givi crash bars, MCA screen, bark busters, rad & bash guards.
1977 BMW R100S - SOLD
1984 BMW R80RT - Sold
1984 DR185 - Retired
timr is offline
post #6 of 43 Old 10-23-2012, 08:03 PM
Borghi's Avatar
I was a non believer at first but after installing a Scott Oiler about a month ago it really does work and works well. Oil on both sides of the chain, no fling off, and very low maintenance. I highly recommend. I read somewhere that Scott has been perfecting these things for 50 years and they really know what they are doing.
Borghi is offline
post #7 of 43 Old 10-23-2012, 10:33 PM
randyo's Avatar
how does the oil get there? capillary flow. it gets there, I've been running a scottoiler on my last 2 bikes (SV650 and my Vee) for over a quarter million miles
I run ATF at a drip rate of one drip per 50 seconds. a quart of ATF lasts me about 7500 miles. decreased my required maintenance by 99% and almost tripled the life of my chain & sprockets
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #8 of 43 Old 10-23-2012, 11:08 PM Thread Starter
wow, you talked mi into it im going to order the system as soon as possible,
do you think the esystem is so better? its about 150$ more than the vacuum one
post #9 of 43 Old 10-24-2012, 01:07 AM
Strange Dog's Avatar
Oh damnit, another farkle I need. My economical Vee is gonna end up costing me $20K.
Strange Dog is offline
post #10 of 43 Old 10-24-2012, 12:18 PM
randyo's Avatar
another mod I recommend, just to make it easier to keep track of sprocket wear
http://www.stromtrooper.com/dl-1000-...tml#post870367
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
Human Verification
