Fixing the Vee - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #41 of 86 Old 10-29-2012, 05:29 PM
I like seeing all of the pictures of the internals, keep them coming please.
I'm sure you will but, I would deburr the edges around that damage. Get them little pieces of shavings out of there.
Did you find all of the pieces of the chain that broke?
HatchXRL is offline
post #42 of 86 Old 11-06-2012, 03:09 AM Thread Starter
OfirMX's Avatar
Well, after being working on the Vee for a good few hours today, this is where it all stands:
I ended up taking from the donor engine:
- The front cam chain.
- The front cam chain guide and tensioner
- The two front intake valves.
Everything else will be the original engine.
Original front cam chain - BUSTED
Original front chain guide - BUSTED
Original front intake valves - BUSTED
So now that I have all the needed parts out, I just need to start putting everything together.
Chain guides are ready
Pistons are clean
Cylinders are clean
Heads are clean
Valves are mostly clean
Now I just need to lap them in place to re-seat them and make sure they seal properly.
Good day today.
- Off
OfirMX is offline
post #43 of 86 Old 11-06-2012, 02:03 PM
Stromtrooper.com Sponsor
Satch's Avatar
Hey Off -- I just stumbled on to this thread. I had no idea when we rode last week that you were this far into the project! I really admire you for taking on this challenge. You have much more patience and tenacity than I have! I'd be happy to come over and help if needed. I can't provide much technical knowledge, but if you need an extra pair of hands let me know.
Satch is online now
post #44 of 86 Old 11-06-2012, 11:08 PM Thread Starter
OfirMX's Avatar
Well, I'm planning on putting the engine back together tomorrow and then maybe mount it in the evening. I know you'll be riding tomorrow morning, but if you feel like dropping by after that, I could use another pair of hands. You got my number, text me and I'll give you my address.
Sent from my right shoe using the Motorcycle app
OfirMX is offline
post #45 of 86 Old 11-08-2012, 10:24 PM Thread Starter
OfirMX's Avatar
It's all coming together.
Chains and cylinders are in place.
Heads are in place:
OfirMX is offline
post #46 of 86 Old 11-10-2012, 04:50 PM Thread Starter
OfirMX's Avatar
Snowing out there. Need a bigger garage heater... And a cup of hot tea.
Sent from my left shoe using the Motorcycle app
OfirMX is offline
post #47 of 86 Old 11-12-2012, 07:29 PM
scott1000's Avatar
And please keep the picutres coming
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
scott1000 is offline
post #48 of 86 Old 11-12-2012, 08:08 PM Thread Starter
OfirMX's Avatar
Valves adjusted and under spec. Only one needed a new shim which, fortunately, I had.
OfirMX is offline
post #49 of 86 Old 11-12-2012, 09:18 PM
K6 engine
Originally Posted by southforkspeedster View Post
Interesting. I had an 06 break a front cam chain also. I have another 06. that sounds like it is about to come apart.............40k on both of mine. I have only heard of one other. Now with yours, that makes 3..........
Don't worry--I have a 2006 with 60,000 miles. It has been ridden hard (redlined regularly) and long (two trips to Inuvik, NWT). The engine runs better than new. I put 12,000 miles on it this year. They're fantastic motors!!
dilrod is offline
post #50 of 86 Old 11-16-2012, 05:30 AM Thread Starter
OfirMX's Avatar
Camshafts in place.
Timing adjusted.
This motor is almost ready!
OfirMX is offline
Human Verification
