Forks rebuild... - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #21 of 25 Old 01-01-2013, 10:06 PM
Laava's Avatar
The std head bearings are budget and worth replacing with tapered. Worked for me!
L4 DL1000 Black Strom No3
Laava is offline
post #22 of 25 Old 01-01-2013, 10:09 PM
bwringer's Avatar
Originally Posted by henerythe8th View Post
On the way:
Sonic springs 1.1
6,7,8,11 & 12 as Greywolf recommended.
Sonic says that they've sent instructions with the springs and say they'll provide technical advice if needed...
...we'll see...
Rick provides great instructions, and he answers his emails pretty quickly.
bwringer is offline
post #23 of 25 Old 01-02-2013, 01:04 PM
Banned
FYI
I had good success buffing with cloth wheel and compound in the direction of travel
Greatly reduced seal stiction and believed it eliminated any weeping
richw is offline
post #24 of 25 Old 01-02-2013, 11:00 PM
If the forks are due for a rebuild, then maybe the steering bearings are also. The infamous clunk is probably something else...maybe the tank moving forward, or...? Some Stroms have it at low mileage and some never get it.
[I]"Older people who are reasonable, good-tempered, and gracious will bear aging well. Those who are mean-spirited and irritable will be unhappy at every period of their lives.
"Let each of use properly whatever strengths he has and strive to use them well. If he does this, he will never find himself lacking."[/I]
post #25 of 25 Old 07-14-2013, 12:14 AM
OfirMX's Avatar
I weigh ~185lbs. I'm going for .90 springs and oil.
In your experienced opinion, for my weight, do I NEED to install new super-expensive valves too?
Also, what oil wt would you recommend me?
OfirMX is offline
Human Verification
