My turn to do water pump seal (sigh) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 13 Old 06-01-2017, 08:33 PM Thread Starter
DesertBike's Avatar
Some time in the past 2-3 months, I started finding small amounts of coolant on the ground after parking the bike. We're talking about maybe a teaspoon, at most, directly below the weep tube coming off the front of the water pump (#11 in this diagram: 2007 Suzuki V-Strom (DL1000) WATER PUMP | PartsOutlaw.com).
From what I've been reading, this means the seal (#3 in the water pump diagram linked above) needs replacement.
While I'm in there, I'm thinking I might as well rebuild the thing, replacing relatively cheap wear items like:
4 OIL SEAL, 09283-10005
6 BEARING, WATER PUMP, 09262-10016 (there are two of these, if I understand correctly)
and top it off with a new gasket:
5 O RING, 17435-02F00
and of course inspect the shaft of:
2 IMPELLER, 17491-16G00
for any scoring/advanced wear.
How long can I put this off? Since I need to drain the oil, I might as well coordinate the job with my next oil change, due in about 2000 miles (~32500 miles overall). I have a jug of Zerex Asian 50/50 standing by to top off the coolant reservoir whenever it gets low.
I have fresh tubes & seals for the rest of the cooling system standing by, just haven't done the work because nothing else is leaking (yet!) and everything but the radiator outlet hose (#3 from the radiator diagram Suzuki Motorcycle Parts 2007 DL1000 RADIATOR HOSE Diagram) is kind of a pain to swap. I have a new #2 hose, pair of #9 O-rings, and #6 inlet connector hoses standing by as well, given those are all rubber items that are going to be degraded after 10 years. So, might as well do the whole job at once.
Do I have that right? Anything else I should replace, on the principle of it being a hassle to get to it again later?
Given the notoriously long lead time for ordering motorcycle parts, I better go ahead and put my order in soon.
DesertBike is offline
post #2 of 13 Old 06-01-2017, 08:42 PM
Moderator++
Since you plane to replaces all that, you should be fine waiting for the next oil change.
DesertBike likes this.
greywolf is online now
post #3 of 13 Old 06-01-2017, 08:53 PM Thread Starter
DesertBike's Avatar
I realized I left something out: might need to replace the clutch cover gasket. Depends on how much it sticks to the rest of the engine.
Or is RTV good enough? I have a tube of the gray Permatex RTV stuff that meets Ford specs for sealing the cover on an 8.8" rear differential, front crankshaft oil seal, and a few other places.
post #4 of 13 Old 06-01-2017, 09:01 PM
Moderator++
Get the gasket.
post #5 of 13 Old 06-01-2017, 09:13 PM
bwringer's Avatar
Agreed. You will definitely need the clutch cover gasket. It will not be re-usable.
bwringer is offline
post #6 of 13 Old 06-01-2017, 10:46 PM
teevee's Avatar
#3 is a pain! fought with that bugger for an hour...
'08 DR650, '07 DL1000
teevee is offline
post #7 of 13 Old 06-01-2017, 11:12 PM Thread Starter
DesertBike's Avatar
Oh joy, I can't wait.
Seems like the main problem the one guy (Black Lab Adventures) had was getting that #3 seal out.
I don't have a proper bearing puller, BUT, I have zero issue with buying a reasonable substitute tool at Horrible Freight. Or wherever. Any tips on the tool that works best?
The proper Suzuki tool is out of the question of course, at $559 (!).
Just realized this is my big chance to check for the dread Clutch Chudder Monster. Oh joy.
post #8 of 13 Old 06-02-2017, 01:19 PM
Double check your hose clamps before buying parts. I had the same symptoms years ago and have yet to replace the water pump. Any coolant leaks have been hoses or clamps.
MittStromney is offline
post #9 of 13 Old 06-02-2017, 03:05 PM
The reason you want a new gasket, besides the obvious fact that some of the original will stick to the engine case while the rest will stick to the cover and leave that mess, is that the water ports have a bead of sealant around them on a new OEM gasket. While a slight seep of oil from re-using the old gasket might be tolerable, allowing coolant into the oil is NOT! Don't buy the ebay gaskets for about $12, these are not OEM and have NO sealant around the water ports and do not have the graphite coating the OEM gasket has. This graphite coating allows the gasket to seat better and allows installation WITHOUT using gasket sealer on it. Yes, install the OEM gasket dry.
As for inspecting for clutch chudder, about the only thing you can see without taking the basket apart is how much movement it has. With the cover off, grab the basket with two hands and twist back and forth. There should be very little play in it. Watch the relationship between the steel gear on the back of the basket and the aluminum basket assembly. If it moves significantly you can bet there is internal wear.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #10 of 13 Old 06-05-2017, 06:12 PM Thread Starter
DesertBike's Avatar
See that's interesting, because the genuine Suzuki clutch cover gasket was about $12. Plus a little change if you include shipping (Partsoutlaw.com has a SMOKIN' deal on shipping). So yeah, of course I got an OEM part.
I replaced the stator cover gasket when I replaced the stator a few months back. As you say, the genuine Suzuki gasket was a breeze to install. No leaks.
Human Verification
