accelerating at a brisk pace (near WFO). No loose mounts; chain in good shape and adjusted properly; TB's synced; 22K miles. Could this be loose alternator magnets, or clutch "chudder" rearing it's ugly head? I did notice that neutral was a little hard to find yesterday during a ride.
Bike is real smooth at idle and normal steady engine speeds. Any help is appreciated. And yes, I did a search but did not find anything specific.
Only feel this vibration when accelerating hard. I'm wondering if my newly installed Rox risers are amplifying the vibes I've never felt before???
Guess there's one way to find out!
The chain and front sprocket have less than 7K miles on them
but the chain is showing some tight links. Maybe the sprocket is bad as well (it's not a factory issue).
The rear sprocket (original) still appears to be perfect. Guess I'll be changing the front and chain again and not be using an RK. Maybe I'll stop downshifting so much to save wear & tear on the drive system.:frown2:
At 22K miles your rear sprocket and chain may be in good shape. But not the front sprocket. I too think this sounds like something I would check right away. Loose rotor magnets are felt in the 4000+ rpm range at all loads and it is a light vibration. Clutch chudder will be felt when not accelerating hard as well as when hard on the throttle but typically you spend much time under 4000 rpm when hard on the throttle so clutch chudder isn't as obvious. At your mileage I expect there is more wear in the clutch basket than you might think, but I would also not think it is the likely source of your vibrations.
Surprised to find the TB sync was off a bit as this never has varied previously. Re-synced with my new CarbTune and she runs as smooth as the inner thighs of a teen-aged beauty queen!
I should have known to never "assume" something is OK and doesn't need checking!
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
