No more Master Mike Spacers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-25-2007, 02:24 PM Thread Starter
I got an email from Master Mike's stating that he is too busy and is not making the spacers anymore. Does anybody know where I could get one or a similar product?
thanks
thopkin1971 is offline
post #2 of 6 Old 06-25-2007, 02:38 PM
Redbeard's Avatar
I'm hoping my package from MM is in the mailbox today when I get home - and no, you can't have it!
There has been talk on the other Strom forum about few people taking over for MM in the US. Nothing set yet - but chances are good that it will happen.
The other option is to take your spacers off, have a machine shop mill 2mm off the one, and make a 2mm shim for the other. Shouldn't be too expensive.
Take care,
Bob S.
DL1000K6 - Gray
Only motorcycle riders understand why dogs ride with their heads out the window.
Redbeard is offline
post #3 of 6 Old 06-26-2007, 07:31 AM
these guys send the stock spacer to a machine shop for a trim, then put a washer on the other side. works great . . . about 8k miles on mine since the fix. cheap too.
http://www.tonupmotorcycles.com/
DLK4
iron butt strommer, daily rider and diehard airhead
mikevstrom is offline
post #4 of 6 Old 06-26-2007, 11:06 PM
RE the washer.... I know from other posts that the spacer trim, and washer thickness, should be the same thickness - about 2mm.
What inner and outer diameter should the washer be?
CarSalesman is offline
post #5 of 6 Old 06-27-2007, 06:06 AM
freddy's Avatar
Could anyone who has a set of spacers that are not fitted post a sketch showing all the dimensions? If that would be possible I'm sure any local machine shop would be able to produce them.
I know spacer #8 needs to be 2mm shorter and spacer #9 needs to be 2mm longer. Does it matter which side of spacer #8 is reduced and which side of spacer #9 is increased?
Fred
freddy is offline
post #6 of 6 Old 06-27-2007, 11:12 AM
Redbeard's Avatar
Fred
My set came in on Monday from MM, I'll measure them up for you if you need it, but I think you can find the answer here...
http://11109.rapidforum.com/topic=10...rch=&startid=2
I'd say more, but I have to go look at your avatar again...
L8r,
Bob S.
DL1000K6 - Gray
Redbeard is offline
Human Verification
