PCIII questions and concerns!!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 336 Old 06-13-2007, 01:06 AM Thread Starter
Administrator
Exclamation PCIII questions and concerns!!!!
Please use this thread for all things pertaining to PCIII mapping. Things like performance, gas mileage, tuning tips, best map for riding style, personal observations & experiences etc.......... List the year of your Strom too, this really helps.
Try to keep on topic as much as possible. Don't post "actual" map files here, post it at the other STICKY map thread.
Have fun......no pissing on eachother please.
2015 DL650 XT "Drill"
post #2 of 336 Old 06-14-2007, 09:47 AM
cmosentine's Avatar
2006 Dl1000
My 1000K6 is stock. PCIII supplied by Fuel Moto with their "stock" map. I get 40 mpg on the road, mid-upper 30's around town. I have a torque-y right hand.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #3 of 336 Old 06-14-2007, 10:30 AM
How's about posting your map on the sticky thread?
darkjedip is offline
post #4 of 336 Old 06-14-2007, 10:30 AM
Cheff's Avatar
'06 V, with my own custom map created by averaging fuelmoto map with several other I have downloaded from other forums. 40+ on the open road, 30+ on my daily commute. I also have a heavy right hand
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
post #5 of 336 Old 06-14-2007, 11:07 AM
cmosentine's Avatar
I don't have it. It came pre-programmed. I'll see if I can dl it from Fuel Moto.
2008 HD FLSTF
post #6 of 336 Old 06-24-2007, 11:10 AM
I just put the unbaffled two bros exhaust on my stock k6 and it has the hicups off idle and between 3500-4000. Im am using the PCIII recomended map. With the stock exhaust the PCIII map was an improvement. I have made no other mods.
Eelspike
K6 two brothers exhaust 14,000 miles commuting to NYC.
eelspike is offline
post #7 of 336 Old 07-21-2007, 05:28 PM
Looking for a littlePCIII map help
I have an 04 DL1000. Stock exhaust with K&N air. I'm running the completely stock map for the 04-05 (M311-005) and believe that it may be running a bit lean. Would appreciate any suggestions.
Turtle is offline
post #8 of 336 Old 07-21-2007, 08:59 PM Thread Starter
Administrator
All great maps located here, feel free to play around with them.
http://www.stromtrooper.com/forums/s...ad.php?t=12806
post #9 of 336 Old 07-21-2007, 09:09 PM Thread Starter
Administrator
I reloaded mine today with MG's new map that he modified for "me". I also saved about 10 other maps as well, in case anyone ever needs them while hanging at my crib. I also have some great cold weather options with a couple of these maps too.
My 1000 honestly 1st though second will reach for the sky under hard throttle....so will BADTRAINDRIVERS strom. I'll see how good the Black Mantis runs with the new map, and I'll get back to ya'll.
post #10 of 336 Old 08-09-2007, 09:24 PM
buttons on PC111
I installed one of Shep's maps in my 06 and it seems a little lean at 3 to 4K rpm. Tried to adjust the mid range button but it would not work as per the manuel's directions. I held the 3 on and switched on ign----nothing, I switched on ign and then depressed the buttons---still nothing. The led moves when the engine is running and the unit took the map so that part works. Any hints?
gcarper1@charter.net is offline
Human Verification
