PCIII Maps for DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 466 Old 06-05-2007, 11:17 AM Thread Starter
MonkeyGrass's Avatar
Send a message via AIM to MonkeyGrass Send a message via MSN to MonkeyGrass
Post PCIII Maps for DL1000
Ok folks, I'm starting a map exchange thread here. Please post your maps, with the following info:
  • Year/Model - please note if this is for an 02/03 or 04+ DL1k
  • Map format - .djm or .map. Try to convert and post both if you can. It's easy just d/l the other software from dynojet.com and copy and paste the map into it.
  • Your setup - if it's a custom map, please let us know what mods you've done to your bike (pipes, intake secondaries, etc..)
  • Any special notes about the map
Since this is going to be a sticky, let's keep the thread purely for posting and listing maps, and discuss them in a different thread so we can keep this clean and easy to browse thru!
[SIGPIC][/SIGPIC][I][SIZE=1][SIZE=3][SIZE=3][B]
V-Strom - embarrassing squids since 2002.[/B][/SIZE][/SIZE]
[/SIZE][/I][FONT=Georgia]DL1000K2 #938
[SIZE=1][COLOR=Navy][B][SIZE=2]Blue, of course!!
[/SIZE][/B][/COLOR][/SIZE][/FONT][FONT=Book Antiqua][SIZE=2][I][B]
R.I.P Jason. You will be missed.[/B][/I][/SIZE][/FONT]
MonkeyGrass is offline
post #2 of 466 Old 06-05-2007, 11:22 AM Thread Starter
MG's Custom Map
I'll start with mine!!
  • 02-03 DL1000
  • I'm posting in both formats
  • Setup: Leo Vince SBK, K&N, Secondaries removed, 43t rear sprocket
This is essentially a hybrid map of several I have tried. I took the best low, mid, and high end out of some maps I liked, and used it as a starting point to begin tweaking. I'm currently thrilled with this map, and I'm getting a solid 43 MPG.
post #3 of 466 Old 06-07-2007, 06:01 PM
MightyShep
Shep's Maps
Here are some of mine. They are by no means scientific. I used the old "trail and error" method.
  • 2006 DL1K
  • Secondaries removed and K&N air Filter
  • Stock Exhaust
/*edit* zip file should now work /*edit*
post #4 of 466 Old 06-12-2007, 11:27 AM Thread Starter
Updates - v7.1
Ok here is my v7.1 map, again in both formats, for 02-02 DL1k's.
This is the low and mid-range from my v6 series maps, with some of the fuel added back into the upper ranges above 6000 rpms. Shouldn't kill your gas mileage too bad, (unless you ride at redline A LOT) I just replaced a bunch of -#'s with some 0's and 1-2's to make sure it has enough oomph on the top end.
File Type: zip MG_pwrcmdr_Mapsv7.zip (1,008 Bytes, 640 views)
post #5 of 466 Old 06-12-2007, 07:28 PM
... keep this clean ...
"let's keep the thread purely for posting and listing maps, and discuss them in a different thread so we can keep this clean and easy to browse thru!"
Seemed like a good idea
How about some moderator (MokeyGrass?) cleaning ?
Hakan is offline
post #6 of 466 Old 06-12-2007, 07:40 PM Thread Starter
GREAT IDEA!!!
Guys, please open a thread to discuss maps/mileage performance etc...
/slaps Shep & Chris on the back of the hand!
post #7 of 466 Old 06-12-2007, 07:43 PM
MightyShep
Originally Posted by MonkeyGrass View Post
GREAT IDEA!!!
/cough/bite me/cough
post #8 of 466 Old 06-13-2007, 12:39 AM
Administrator
GREAT IDEA!!!
Final goofy posting "because I can"! We could call this Monkeying with Maps....or Maps by Monkey. I for one think this is a great idea, for those of us using the PCIII or thinking about taking the plunge.
Okay....no more BS posts!!!!
2015 DL650 XT "Drill"
post #9 of 466 Old 06-14-2007, 10:38 AM
Cheff's Avatar
Cheff maps
'06 dl1000
There is 3 maps here.
2 of them were created with a dyno and an '05 V. I then took those maps and averaged them with the fuelmoto stock map until I got the one I like the best.
Let me know what you guys think of my map.
The other 2 are also very good, one is tuned for best fuel/air mixture and its the economy map, the other one created on the same day and dyno for best performance HP/torque.
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
post #10 of 466 Old 06-14-2007, 11:37 AM
Cheff's Avatar
Stock Fuelmoto map for '06
Here is the Stock Fuelmoto map that came with my PCIII from Fuelmoto
File Type: zip fuelmoto.zip (535 Bytes, 752 views)
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
Human Verification
