Stromtrooper Forum : Suzuki V-Strom Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Forums > Popular Forums > DL 1000 Specific
DL 1000 Specific For those bikes with two pipes
  #11
Old 11-12-2009, 08:41 AM
bwringer's Avatar
The sales droids at Ace (or any hardware store) are worse than useless when it comes to metric stuff. And yet they won't just go away and let me rummage in peace...
1990 Suzuki VX800, Candy Luxury Maroon. And dents.
1983 Suzuki GS850G, Cosmic Blue.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 11-12-2009, 08:36 PM
Many spark plug sockets have a 19mm end. Just push a short 3/8" extension through the "wrong" way and you've got the tool you can use with a standard ratchet handle.
If you get to it...
and you can't do it...
then there you jolly-well are,
aren't you?
---Lord Buckley---
Old 12-23-2009, 03:23 PM
I found them in the section of "Metric drawers" with one drawer marked "Coupling nuts". The salesman even let me use a 19mm wrench to check that I had the right one.
Thanks for the idea!
2006 Suzuki Vstrom DL1000 (Red)
Old 12-23-2009, 07:35 PM
Jim Davis's Avatar
Stromtrooper.com Sponsor
Unfortunately many of them won't accept the ratchet square drive from the other side.
I solved that though by grinding the socket off leaving the 19mm end, perfect for my ratchet. I believe the original spark plug socket was a 16mm.
This tool worked really well and it's really small to, for storage in the toolkit.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Old 12-23-2009, 10:29 PM
bwringer's Avatar
Very niiiiiice!
Once you start looking, 19mm and 3/4" hexagonal objects are everywhere...
Old 12-24-2009, 02:57 AM
Skinnifatkid's Avatar
I was at Rona (Local Hardware like Home Depot) and found them in the tool corral and found a 12mm and 19mm allen key.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1 PL1
