Battery died somewhat abruptly...what am I looking at? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #11
Old 12-10-2012, 09:22 AM
CanadianFZ6's Avatar
Never disconnect the battery from a running engine. It buffers charging current. Without it, the regulator/rectifier and even the onboard computer can be damaged.
I didn't know that.... Yet another good tidbit of info from your Vulcan mind...
'12 DL650 Glee in White
Never argue with an idiot; people watching may not be able to tell the difference.
Old 12-10-2012, 04:21 PM
maximilian's Avatar
Thanks for the responses. I'll load test the battery and see its "health". Tested the generator output again this morning. Now I'm seeing 13.5, which would be normal for a charged battery. Load test will narrow it down.
Again, thanks for the input.
'06 KLR650
'78 CB750
'04 DL1000
Old 12-10-2012, 04:45 PM
LoneStrom's Avatar
Did you check the 3 outputs ??
1982 GS850..BLACK SUNSHINE,the tripod
2007 DL996AR..BRUTUS
Ah screw it,I'm goin ridin !!!!!!!!
Old 12-11-2012, 12:51 PM
I personally am betting on cascade failure
moving magnets lower voltage raising the amps
Higher amps burn stator
I will have a healthy battery best yuasa I can get in there then monitor voltage and if/when my signal dynamics stays yellow I will open her up
You need some voltage monitoring
Link Click Here >>> 2013 Northeast V-Strom Rally!
FILL OUT NEVA MEAL POLL If your attending
Also in events
8/2/2013
Old 12-11-2012, 08:24 PM
Let's say that it takes maybe 15% of your battery's capacity to start the engine. And the battery ages and loses 20% of its capacity each year. After the first year your battery is down to 80% at best, but no problem. Third year, 40% capacity but it only takes 15% to start, still no problem. Fourth year, 20% available; 4-1/2 years it gets dicey...and one day your battery dies "suddenly."
Your numbers might be different, but the process is the same.
Yes, there might be a charging problem. Do check the charging voltages on the three phases from the alternator and pull the cover to check that the magnets are tightly glued and in evenly spaced positions.
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 12-11-2012, 08:53 PM
janiceclanfield's Avatar
Default Battery died somewhat abruptly...what am I looking at?
I would assume you're looking at your keyboard and monitor.
2003 DL1000 - Freya, Leather Winged Demon of the Night
Old 12-11-2012, 08:59 PM
First thing (and easiest) to check is the battery. Batteries can , and do, suddenly die. I have had a couple act just as you describe.
Rod
Old 12-14-2012, 03:13 AM
maximilian's Avatar
Turned out to be something related to the heated grips. Turned them off, and the battery is charging like a champ. Not sure what the issue is in the grips which would be drawing sufficient amps to overpower the bike's charging capacity, yet not burning something up....but it doesn't matter much, since it is what it is. At least I have the problem isolated.
'06 KLR650
'78 CB750
'04 DL1000
Old 12-14-2012, 09:06 PM
ozart's Avatar
To be continued ...
Old 12-15-2012, 10:19 AM
sempervee's Avatar
After 5 years of no issue perfect starting - mine died completely after a short 15 mile ride to a friends house..
Took it to a auto parts store to load test - showed ok - don't trust it and good insurance to buy new. Bought new Walmart Yuasa battery and no more problems!! It was just old and time. many starts later no issues.. just needed a new battery thankfully.
The old days of unhooking battery charging check now cause NEW problems with electronics.
Riding since 1973
If Evolution is outlawed... Only outlaws will Evolve.
* 2012 V I C T O R Y Cross Country Tour
2007 1000 " VroomHilda"
2007 Moto Guzzi 1200 Norge - La Dolce Vita
