#61
So would it (the new motor) be worth waiting for? I do prefer the look of the old bike though.
| Sponsored Links | ||
Advertisement | ||
#62
I would not buy a new V until alot of others have bought them and reported back here,I'm guessing they did NOT address the FI and clutch issues..
1982 GS850..BLACK SUNSHINE,the tripod 2007 DL996AR..BRUTUS Ah screw it,I'm goin ridin !!!!!!!! |
#63
I disagree
I think you will have O2 sensor closed loop FI system which should address the running issues. Chudder, if she's smooth running chudder will be minimized but not eliminated. I own a Vstrom 80% for the FRAME, not the engine. I wanted the blend of long legs and go any road. I pass a lot so the 1000. Oh and cheap.. I got mine as a left over so 1/2 what a new one 1/3 of a BMW or KTM. As the West and the USA in particular become insignificant there will remain only lip service to our EPA and market. If a bandaid gets the EPA off their back then thats that. So if a 2013/14 still allows you to go long distance and go on any road, and be cheap compared to others then its a winner.
Link Click Here >>> 2013 Northeast V-Strom Rally! FILL OUT NEVA MEAL POLL If your attending Also in events 8/2/2013 |
#64
'12 DL 650- '04 DL 650- '03 DL 1000- '04 R 1150 RT WERKS modified clutch baskets for DL and SV 1000's. The BEST in chudder control, noise control, and lasting durability! AVAILABLE HERE: www.werksparts.com Want straightforward easy to understand answers to clutch basket questions or concerns? E-mail Terry info@werksparts.com |
#65
So yeah, I'll take it upon myself to post the closer here. After several years of corrective therapy by the crew here at Stromtrooper I have reluctantly taken my meds and done the following... 1.) Front fork brace. 2.) Installed 3mm off-set shim in rear axle. 3.) Wind buffeting part one: Loose the stock mirrors for a set of Aprilia Tuono units. 4.) Wind buffeting part two: Install a Cee Bailey windscreen on a set of Madstad brackets. 5.) Replace any questionable sensors on the bike and do ALL the T-Body recalibration procedures before coming here and complaining about crappy running issues. <yes, I got spanked> and yes, I learned that a TPS can test good and be bad. Sage advice from the wolf, "just change it and be done with it" 7.) Installed a re-werked clutch basket. (chudder or no chudder, just do it and be done with ALL clutch issues forever!) 8.) Put the fueling bugs to sleep. e.g. Build, buy, or steal a Yosh, Teka, or Power Commander device. They work wonders. It's a game changer. 9.) Time bomb issues: I'm on my second stator. Only God knows when she'll fry again so it's literally a time bomb. <suggest a rabbits foot> 10.) I'm running my original fuel pump with 40+ thousand miles on it. There are two options here. Simply install a new $700.00 fuel pump every 50,000 miles, or... go with the rabbits foot option mentioned in #9 above. 11.) Installed 16/43 gearing. This one is a personal preference. For me it was a great improvement. So lasersage, I have an 06 Vee (same as the 07 you rode) and I love the thing. I think you should buy that 07 Vee and begin the journey from frustration to Nirvana. Hello? lasersage? Hey, where'd he go?
A "Commuter" not an AdvTourer. Currently Commuting On: 06 Harley XL1200C, 06 DL1000, 07 GS500F, 2 mopeds, and a pair of sneakers. |
#66
Starting Jan 1st ( unless I see a new bike at the show next weekend I can't live without ) I'm buying a PC followed by a modded clutch basket,After that comes a rear shock and pile up another 50,000 miles WITH a rabbits foot zipped tied to the bars !!!.
#67
You are indeed one of my favorite DL1000 posters, (um slanderers). Trust me Sir, I'm with ya' on the frustration issue. Next time your in Central Jersey, give me a ring because... I know a guy, that knows a guy, that has a Teka-2 and a dyno. <cough-cough> ![]() Same guy could probably fabricate you a 3mm rear sprocket off-set kit for little more than postage. It might help you from eating sprocket sets over and over. Oh, and the thing they don't tell you about the rear spacer trick is that anything more than a couple mm of offset and your gonna' need to offset the rear brake caliber too or you'll simply trade sprocket problems for brake problems. Just sayin'. So, if you just got the O.K. from your CFO (wife?) to spend the money to "fix" your Vee, then just do it, and I'm outa' here. But otherwise, if your broke (like me), PM me and I may be able to help you dismiss the fueling issues and such on the cheap. Your move. -Ej-
#68
I use to be in Jersey alot ( Milford ) but the family moved away !!.I would love to just go get a NC700x or a CB500x but it will be nice to not have a payment anymore,and that $137 a month I save can go towards more parts and tires to keep the old girl going !!.
#69
Can't see why all the earlier bikes positives won't be there in the new model. Most of the negatives in the old bikes dependability would be due to a fault in a certain component or particular batch of parts supplied by third parties. By now Suzuki should have screwed those bad suppliers to the floor and got them to correct their ways. Should pose less of a threat where any item stays the same in the new bike. Its more often in the all new or re-designed components where the opportunity for new issues is presented. For that very reason Suzuki will have left as much as possible the same in the new engine. New cylinder head and fuelling are definately changed because they have to for emissions regulations and we see the pictures. I think they will have left the rest of the engine just as it was. Why suffer the cost of change and risk new issues if there's no need. If the FI is good we should know fairly soon after the first rides. My guess is Suzuki and their suppliers of clutches both think the chudder issue is behind them. Only time or a look at the new bikes parts list will tell if they tried to address this yet again. Confident I can still modify them care what. Shipped two modified baskets to Japan this year. Would be nice to think that was the manufacturer having a look what sorts them out. Replies back from both owners saying they are fine. Perhaps not. Only time will tell if the new cylinder heads and other changes to affected components such as cam chain guides are as durable as the old. Something odd about adding a new spark plug off to the side of an exisitng four valve head. Centre plug, valve angle, piston crown and squish band (shape of the combustion chamber) would have taken years to develop to ensure reliability and durability in the old engine. That must have all gone out the window with the new extra plug in the corner arrangement. I do hope its not just an experiment or stop gap to get the lovely engine back in production. PAIR was.
this sig line is manually removed. change this again to anything other than a blank and you will be removed. -admin |
#70
Has anyone had any of the big 3 problems ( clutch,FI or stator ) taken care of by Suzuki at no cost ???.
| Sponsored Links | |
Advertisement | |
| Tags |
| buy, dl1000, surging, test ride |
| Thread Tools | |
| Display Modes | |
