Test rode a dl1000, mixed feelings - Page 6 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #51
Old 11-26-2012, 03:22 PM
Moderator++
Originally Posted by LoneStrom View Post
Don't all the auto makers need to pass EPA regs??,my FI cars run great no fueling issues!!.
Cars get new engine designs every few years. Suzuki doesn't sell enough DL1000s to redo the engine. The DL650's design is newer and it still got a makeover on 2007 and again in 2012 because they sell more.
Old 11-26-2012, 04:25 PM
LoneStrom's Avatar
Thats my point,Suzuki COULD fix the problem BUT since we don't stop buying it there is no imcentive for them to put any $$ into it.If the model tanked becuase of the problem they might fix it but they would probably just drop the model..
1982 GS850..BLACK SUNSHINE,the tripod
2007 DL996AR..BRUTUS
Ah screw it,I'm goin ridin !!!!!!!!
Old 11-26-2012, 04:28 PM
Scott E. Bonds's Avatar
Lonestrom, I understand your frustration. Greywolf is correct also. Remember, your car has a cat (catalytic) convertor and a closed loop EFI system. By closed loop, the exhaust has O2 sensors down and upstream of the cat monitoring combustion efficiency. So your modern car and many bikes are constantly adjusting the EFI for maximum efficiency and acceptable drivability. The Vee is an old design.
I bitched when I first got mine thinking I could tune out the issues. But I could not and hated the low rpm mapping. Is it illegal to remap by a dealer...likely so and I will not publish who did mine but what I did do was ask around the better shops for who had a dyno. This will likely be the shop who has a yosh box. The dealer that did mine did two things (at my request)..he plugged the PAIR valve (which I left on the bike just in case) that injects air back into the cylinder. Then he remapped the fuel tables for maximum hp and torque by richening up the lower end of rpm. The top end is fine on Vees because EPA does testing off idle mostly and the bike manufactureres know this.
My bike picked up about 6 hp if I recall but I wanted smooth low rpm trail and traffic power. I got it first tune. The bike lost a few mpg and runs slightly rich by plug indications and exhaust smell.
I hate to be a polluter but with old bikes you must choose one over the other. As a benefit, our dinosaur designs do not require unleaded since no cat is in exhaust....so if you ever go where no lead is not availablke you are ok with most any flamable swill.
A fuel controller will accomplist the same thing but you either need to trust anothers settings as your entry, or still dyno tune the bike.
2007 Blue SuperVee 1000
2002 White HD Road King Police
2000 Red Honda XR 400r
Old 11-26-2012, 05:12 PM
LoneStrom's Avatar
We lost 2 dealers here in the last year so finding one with that box might be hard.Maybe I will just buy a PC,Early Xmas present !!.
Old 11-27-2012, 05:32 AM
svman's Avatar
Nearly the same engine here in the UK SV1000 has an Oxygen sensor in the pipe beneath the engine and what looks like a small cat in the very front of each can. This since introduction in 2003. I find the engine is smooth in the lower ranges without glitches at all. They could have done the same for US market DL1000.
Perhaps US regulations are not so keen for motorcycles as they are for cars to give the home manufacturers with those old air cooled engines a chance? If Suzuki don't need to spend on modification and extra approval for that market they won't.
Any engine with PAIR is old design trying it's best to be clean for the tests at idle and just off. All pair does is pump air into the exhaust gas as it leaves the cylinder head. Air plays no part in the combustion process as it enters down stream of the exhaust valve. Just thins (dilutes) the dirty gas so it will pass the regulations as it exits the exhaust pipe where it's measured. Test checks volume of dirty gas versus clean gas. Add more clean gas before it comes out the pipe and its said to be a cleaner engine. Truth is it makes just the same muck.
Triumph just fitted PAIR to their latest Boneville engine here. Made to look like a fancy spark plug cover with a plug lead.
I hope to get a good snoop round the new 2014 1K VStrom in a day or so. New cylinder heads will be one area of great interest. Expecting the PAIR system has gone and an extra spark plug in place. Report back if anything worthy of note.
this sig line is manually removed. change this again to anything other than a blank and you will be removed.
-admin
Old 11-27-2012, 08:33 AM
See if left case is bigger/wider to accommodate more electric generation
You would be best to look at clutch cover to see if there is a modification
I would be very surprised if she doesn't have O2 sensor closed loop efi. This would solve many of the VEE problems
We here expect a verbose report.... carry on
Link Click Here >>> 2013 Northeast V-Strom Rally!
FILL OUT NEVA MEAL POLL If your attending
Also in events
8/2/2013
Old 11-27-2012, 03:55 PM
Electrojake's Avatar
Yes indeed SV,
Even if you run a new thread on the subject, please be sure to report back here if you can get a lOOk at that new DL mill.
A "Commuter" not an AdvTourer.
Currently Commuting On: 06 Harley XL1200C, 06 DL1000, 07 GS500F, 2 mopeds, and a pair of sneakers.
Old 11-28-2012, 05:54 PM
mine doesn't do the pulsing and the front brake seems good. It sounds like a "bad bike" and I'd stay away from it.
Old 11-28-2012, 06:09 PM
hunt1moore's Avatar
The new motor definately has another spark by the looks of it.
PC-V, TRE, CR8EIX plugs, Madstad bracket, Madstad 22" shield, Fork brace, 17/43 gearing, Airhawks, Chinese mirrors, mirror extenders, RDL.
Old 11-29-2012, 04:16 AM
svman's Avatar
Definately does. Here's hoping the fuei injection is all refined and only sips at it for a decent range.
Clutch cover and Generator covers are exactly the same as existing. Could be they changed the insides without altering the covers. That said I think they would have been tempted to change the style outside to promote anything new inside.
-admin
Tags
buy, dl1000, surging, test ride
