Test rode a dl1000, mixed feelings - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #41
Old 11-25-2012, 10:08 AM
svman's Avatar
Default Why fix whats not broken?
Originally Posted by Newfie-Strom View Post
Every bike has a little glitch here or there...
Mine has not developed the chudder yet, & juring the off season i will spend an afternoon doing the free washer mod, to ensure i don't find out what chudder is...
May I politely suggest you don't shim the damper springs with washers or anything else for that matter. If you don't have the chudder then don't invite trouble. Enough of these engines seem to never get the chudder or it's not severe enough to be hacking the owner off.
About one in four of the many clutch baskets sent here from the US for the sharealike full re-engineering have been tried with shims or washers. One of the oldest tricks in the book to try and patch up a completly shot clutch basket damper. Owners reported they had made things worse in what had not been that bad to start with. Certainly not better. Hence they had to remove them again and sent them over. Enough pictures and movies about on the forums once they are open to demonstrate what's wrong.
Svman - sharealike everywhere else
Testing, Testing 1,2,3
Old 11-25-2012, 12:56 PM
Electrojake's Avatar
Enough of these engines seem to never get the chudder...
My 2 cents worth:
My 06 Vee got a new (um, reWerked) basket at 40,000 miles however it never had the chudder problem. Which I guess is indeed proof that some bikes can run a stock basket and not have chudder.
I felt it was odd that with all the things wrong with my bike, chudder was never one of them.
The dreaded clutch-slap issue, now that it did suffer from real bad and the modded basket cured it 100%.
But never chudered.
A "Commuter" not an AdvTourer.
Currently Commuting On: 06 Harley XL1200C, 06 DL1000, 07 GS500F, 2 mopeds, and a pair of sneakers.
Old 11-25-2012, 01:42 PM
LoneStrom's Avatar
Nice thing about the chudder is that I guess it's more anoying than anything,I have had it for almost 30,000 miles.
1982 GS850..BLACK SUNSHINE,the tripod
2007 DL996AR..BRUTUS
Ah screw it,I'm goin ridin !!!!!!!!
Old 11-25-2012, 04:41 PM
svman's Avatar
Can be very, very annoying in some bikes though. If not so bad or there at all then leave well alone - better than risking this with shims.....
This basket came here with shims in all six springs. Look how the basket swings from side to side at the hub and is pivoting about the spring at the top. Its supposed to rotate slightly about the hub as it absorbes the torque pulses by deflecting the springs in a set sequence. Other than the play at the hub seen here they go solid as far as the engines pulses are concerned.
Shims in the springs - DON'T DO IT - DON'T Pre-load your springs like this - YouTube
Lucky he did not carry on to find it broke or damaged the springs after 8,000 miles like here.
Broken and chewed phase two spring.
All that was left of the shims and broken springs in the basket. Owner needed to go search his sump for the rest.
Might pay to understand just what the PO might have done to try and get rid of the chudder when buying a used V.
Old 11-25-2012, 06:22 PM
Newfie-Strom's Avatar
That last pic is definately the wrong washers, & who knows .... he may have screwed up the mod himself.
I'll wait until i develop chudder i guess,,,then i'll do the washer mod. Alot of riders seem to be happy with it.
The aftermarket baskets available by a few members here are no doubt the way to go with money not being an issue, but i like to atleast try to get away without spending anything works most times...if not...then i unwillingly throw money at it
Old 11-26-2012, 08:33 AM
svman's Avatar
Was hard to believe those washers were all the same when knocked in. Angle of that picture makes those at the front look larger. Slightly larger hole in their middle is to clear the extra spring in the SV or the spring enlarged some. Owner said he followed instructions from one of the basket modification threads posted a few years ago on VSRI or here. Washers were at the suggested end of the springs (or sign of where they had been).
I don't throw money at anything either unless there is no option. I'm the very guy who first came up with the after market modification for SV and DL some years back - some owners were changing their baskets almost as frequently as their rear tire. I'm re-engineering the inside back to better tolerances than stock rather than shim with washers etc. Made the re-engineer available purely so owners had a choice and did not take risks with shims and washers.
Svman known as sharealike everywhere else.
Old 11-26-2012, 01:38 PM
Scott E. Bonds's Avatar
The real peoblem is that we as riders/consumers keep buying bikes that have know issues so Suzuki has no reason to fix the problems!!.
Your old bike was built before EPA. Your strom was not. Send hate mail to the EPA.
Mine has 80,000 miles on it. After doing the obvious TBS and TPS adjustments...or I should say check as mine were spot on I had the bike remapped with a Yosh box (at 35,000 miles) ....cheaper that a fuel controller since I am not a modder. My brother was hard headed like some here and lived with the fueling issue till I bought the bike and fixed it.
Other than that, I put in a fuel filter at 55,000 miles. Lots of gas, many tires, and more smiles than any other bike I have ever owned. One valve adjust.
Somebody bitched about chain and sprocket wear...mine goes 25,000 to 30,000 miles on a set (happy with that).
Cluch chudder, I have it buts it is very mild and occurs only under load on steep hills in low gear when the bike catches me sleeping in the wrong gear.
I expect 100,000 miles out of the bike....definite keeper for me as I ride 15,000 miles a year on average and its now my only licensed bike.
2007 Blue SuperVee 1000
2002 White HD Road King Police
2000 Red Honda XR 400r
Old 11-26-2012, 02:31 PM
LoneStrom's Avatar
So do dealers have this yosh box,is it cheaper than a PC ??.
I'm not going to ever mod it so a 1 time deal sounds better!!.
Old 11-26-2012, 02:51 PM
Moderator++
It can be hard to find someone with a Yosh box as a dealer remapping the fuel range outside EPA guidelines is against the law. A Yosh box remap is a service only, the remapper only buys the box once, keeps it, and uses it to change the mapping of the stock ECM on any number of bikes. As such, it should be cheaper than buying a PC. A power commander has to be bought and stays on the bike as it alters the map, not by changing the stock values inside the ECM, but only changing the signals outside it.
Old 11-26-2012, 03:04 PM
LoneStrom's Avatar
Don't all the auto makers need to pass EPA regs??,my FI cars run great no fueling issues!!.
Just sayin!!
Tags
buy, dl1000, surging, test ride
