So my DIY Yosh Box Idle Circuit thing works great. But, I want to decrease the effectiveness of the adjustment knob.
Here is the original voltage divider. ![]() 5v comes in and the pot varies the output from 0v to 5v. Our range of adjustment for just fixing the idle should be somewhere between 2v & 3v. Here is a picture of what I am thinking might help me in my predicament. ![]() I read that adding resistors to the circuit can help step up the voltage on the bottom side creates a floor voltage and a resistor on the other side can create a ceiling voltage. Am I right? If so, how do I determine what values I need to get there? FYI, the pot is a 10K linear job. Thanks in advance!
2003 DL1000 K3 “The inherent vice of capitalism is the unequal sharing of blessings; the inherent virtue of socialism is the equal sharing of miseries.” - Winston Churchill |
| Sponsored Links | ||
Advertisement | ||
#2
FIRE BAD !!!
Is this between temp sensor and ECU ? Circuit one picture bad looks like a dead short which would be bad JUJU Once you let out the magic smoke it stops working
Link Click Here >>> 2013 Northeast V-Strom Rally! FILL OUT NEVA MEAL POLL If your attending Also in events 8/2/2013 |
#3
No, this is for my Yosh Box thing that I made. Remember this thread? Yosh Box Idle Adjustment Circuit - Someone Proof it please Just trying to get some input on my adjustment pot. No fires Rich, promise!
#4
This will give about a 1.93V to 3.15V voltage swing range on the output.
Bikes currently own: 2003 Vee Strom, 2008 Kawasaki KLR650,2002 Yamaha FZ1, 2003 Honda Superhawk |
#5
I will run to the Shack tomorrow and see if I can get this done. I also need to solder in my silly test leads so I can have that permanently attached and have a multimeter running side by side to test that voltage. AND THANK YOU!!!
2003 DL1000 K3 “The inherent vice of capitalism is the unequal sharing of blessings; the inherent virtue of socialism is the equal sharing of miseries.” - Winston Churchill Last edited by marshallnoise; 11-10-2012 at 09:56 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
