Fixing the Vee - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #41
Old 10-29-2012, 04:29 PM
I like seeing all of the pictures of the internals, keep them coming please.
I'm sure you will but, I would deburr the edges around that damage. Get them little pieces of shavings out of there.
Did you find all of the pieces of the chain that broke?
Old 11-06-2012, 02:09 AM
off1's Avatar
Stealth Rider
Well, after being working on the Vee for a good few hours today, this is where it all stands:
I ended up taking from the donor engine:
- The front cam chain.
- The front cam chain guide and tensioner
- The two front intake valves.
Everything else will be the original engine.
Original front cam chain - BUSTED
Original front chain guide - BUSTED
Original front intake valves - BUSTED
So now that I have all the needed parts out, I just need to start putting everything together.
Chain guides are ready
Pistons are clean
Cylinders are clean
Heads are clean
Valves are mostly clean
Now I just need to lap them in place to re-seat them and make sure they seal properly.
Good day today.
- Off
Old 11-06-2012, 01:03 PM
Satch's Avatar
Stromtrooper.com Sponsor
Hey Off -- I just stumbled on to this thread. I had no idea when we rode last week that you were this far into the project! I really admire you for taking on this challenge. You have much more patience and tenacity than I have! I'd be happy to come over and help if needed. I can't provide much technical knowledge, but if you need an extra pair of hands let me know.
Old 11-06-2012, 10:08 PM
off1's Avatar
Stealth Rider
Well, I'm planning on putting the engine back together tomorrow and then maybe mount it in the evening. I know you'll be riding tomorrow morning, but if you feel like dropping by after that, I could use another pair of hands. You got my number, text me and I'll give you my address.
Sent from my right shoe using the Motorcycle app
Old 11-08-2012, 09:24 PM
off1's Avatar
Stealth Rider
It's all coming together.
Chains and cylinders are in place.
Heads are in place:
Old 11-10-2012, 03:50 PM
off1's Avatar
Stealth Rider
Snowing out there. Need a bigger garage heater... And a cup of hot tea.
Sent from my left shoe using the Motorcycle app
Old 11-12-2012, 06:29 PM
scott1000's Avatar
And please keep the picutres coming
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
Old 11-12-2012, 07:08 PM
off1's Avatar
Stealth Rider
Valves adjusted and under spec. Only one needed a new shim which, fortunately, I had.
Old 11-12-2012, 08:18 PM
Default K6 engine
Originally Posted by southforkspeedster View Post
Interesting. I had an 06 break a front cam chain also. I have another 06. that sounds like it is about to come apart.............40k on both of mine. I have only heard of one other. Now with yours, that makes 3..........
Don't worry--I have a 2006 with 60,000 miles. It has been ridden hard (redlined regularly) and long (two trips to Inuvik, NWT). The engine runs better than new. I put 12,000 miles on it this year. They're fantastic motors!!
Old 11-16-2012, 04:30 AM
off1's Avatar
Stealth Rider
Camshafts in place.
Timing adjusted.
This motor is almost ready!
