Sidestand foot - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #11
Old 03-25-2012, 06:29 PM
Default Sidestand foot
Hi Mac, I have the S-W Moteck centerstand and no problems.
Old 03-25-2012, 06:32 PM
Mac, I have the S-W Motech centerstand and no problems.
Old 03-25-2012, 06:41 PM
Lesman's Avatar
I welded a very large washer to my sidestand....no problems
I own the Bestest Strom in the World!!!!!!!!!!!!!!!!!!!!!
Old 03-26-2012, 01:10 AM
Banned
Originally Posted by Nyparrothead View Post
Hi all,
I have seen something for the Wee but not the Vee... Anyone make a sidestand foot add on the the 1000. Tired of dents in my driveway and tin cans....
Mark
Don't the wee and vee share the same sidestand?
Old 03-27-2012, 09:10 PM
Hey Nyparrothead,
I hear your concern bub. My Vee, same issue as well as the side stand being too weak and bending causing more of a lean on the bike...not a bad thing, just not a plesant thought knowing your side stand is weak sauce.
Solution- I bought a center stand from Suzuki(same price accross the board and its a solid fit and really good engineering, solid welds, high quality steel and hardware). Center stand works great and I beefed up the side stand and put her back on. Center stand will run you about 260-280 depending on where you go and if they have any special dicounts
Old 03-28-2012, 02:04 PM
Tall Man's Avatar
No. They are different.
DL1000K9
YW125A
Old 03-28-2012, 03:08 PM
Hi,
I have a center stand.. I would like to use the side stand without worrying that it will drive itself into the ground
Mark
Old 04-25-2012, 07:39 PM
Kurgan's Avatar
I just TIG'd a new pad on to the existing foot. Slight trim fitting and work with the belt sander, it clears the exhaust by 1/8".
I hit the bead blasted section with primer and paint, we'll see how it works out this weekend. The bike should be good to go on surfaces it previously sank into to as the new foot has 4.5x the surface area.
Jim
2006 Gray Vstrom 1000
