Secondary Throttle Body Removal - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #21
Old 10-28-2012, 04:39 PM
Originally Posted by scott1000 View Post
i admit
i too hace considered removing mine.. Even went to one time. But to my shock and surprise, the PO stripped one of the @#$ screws out. I tried and tried but canot get the last one out.. Anyone got a trick to removing a little stripped screw from this area? I assume it means either removing the throttly body's.. If that's the only way I will leave it alone.
Leave them in, no real advantage to having them out.
BRIAN
2008 WR250R 2008 CONCOURS 1400 "Dearly departed 2005 DL1000"
Old 10-28-2012, 05:50 PM
scott1000's Avatar
Leaving them in but properly adjusting them seems to be the most widely accepted method. I can say that after getting them adjusted as closely as possible it did smooth things a bit. All around my Vee is very happy right now- so time to leave it alone..
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
Old 11-06-2012, 08:32 PM
Newfie-Strom's Avatar
Removed mine, after 1000 km on my newly aquired V.....i like it. Done a TBS, & LOVE IT !!! I can now stay at 100 km per hour in OD....without a problem rolling the throttle on, & not the slightest hesitation, or stumble at all. She is barely revving....just coasting. Gotta save on the gas that way....i may have to calculate it some day
Old 01-11-2013, 02:14 PM
i yanked mine and use a powercommander with the accelerator pump function to smooth things out. Much prefer the more agressive feel
Old 01-11-2013, 05:34 PM
JRWalker's Avatar
Originally Posted by grantizzle View Post
Yes, I did some research . the "secondary removal" threads all turned out to be ... ....
secondaries limit top speed. remove for full power.
fuelly link: http://www.fuelly.com/driver/jbw/dl1000
