Horn Upgrade? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 02-27-2012, 05:21 PM
Default Horn Upgrade?
Has anyone upgraded their horn? How easy was it to install? Any recommendations for brands? Thanks!
Old 02-27-2012, 05:57 PM
A relay is recommended. Run new power to the relay with a fuse in the positive wire (always run the negative wire back to the battery on our bikes with aluminum and steel frames). Trigger the relay off the power to the stock horn. Use a pair of FIAMM Freeway Blaster horns or a Stebel Nautilus air horn (I used a Stebel on the left side and a lo-tone Freeway Blaster on the right, wired together).
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 02-27-2012, 06:17 PM
andreas's Avatar
Easy to do. PWD has a kit for the storms. Think Gary just finished
the 1K kit. Should have everything you need.
FB MEMBER #133 - 2008 Wee
Old 02-27-2012, 06:42 PM
gryphon51's Avatar
outcast.....
Please elaborate who is this Gary? where is PWD?
Old 02-27-2012, 08:02 PM
Utah
Pat Walsh Designs
DL1000K7
Old 02-27-2012, 08:12 PM
grantizzle's Avatar
I'd be interested in this, but i don't see the 1k kit on his site.
2005 V-Strom 1000 and a severe case of the farkleitis.
Old 02-27-2012, 08:48 PM
Voltar's Avatar
Just speaking as a satisfied PWD customer.... Gary is wonderful to work with. I do not think he has a dl1000 mounting kit.
Old 02-27-2012, 09:16 PM
andreas's Avatar
Sorry about that. http://www.stromtrooper.com/29031-pa...h-designs.html , Gary is also a Forum Sponser.
Old 02-27-2012, 10:06 PM
PWD's Avatar
PWD PWD is offline
stromtrooper approved++
To clarify what Andreas mentioned, I currently provide a plug-n-play Stebel horn kit for the DL650.
I have just recently completed a prototype for the DL1000. I am currently having components fabricated, but the DL1000 kit is not quite ready for sale. I hope to have kits available in 2-3 weeks. As with the DL650 kit, there will be a discount for Stromtrooper members when it's available. Please feel free to email me directly if you have any specific questions.
Thanks,
Gary
PWD
You can find PWD V-Strom accessories at pwdmoto.com
Questions? Email Gary
Old 02-27-2012, 10:20 PM
Flying Pig's Avatar
Stebel seems to have the most popular air horns. I had one in one of my previous bikes which sold me on it so I bought one for my V-Strom. The horn itself isn't very expensive at all, I think it comes in at under $40. But it comes with just the horn and one bolt and nut for mounting. Where you mount to or what you mount with is your prerogative.
Different companies sell different mounting and wiring options. Mounting options can easily be fabricated from parts from your local hardware store if you are crafty. And the wiring isn't difficult if you understand the basics of electricals, but be warned that the manual/schematic included with the Stebel horn is small and hard to read. Luckily there are plenty of online guides.
I wired mine up on my own and it just took a bit of patience to figure out where to plug things into and it worked the first time I tested it out, no issues
Eastern Beaver and a few other sell wiring kits if that's not your thing.
And if you want pure simplicity when it comes to the install, definitely contact Gary from PWD. I've recently bought some farkles from him and am one of his many satisfied customers
When was the last time you checked your tire pressure?
