why so wet - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 05-03-2010, 10:10 PM
Dorzok's Avatar
Default why so wet
Real oily down by the shift lever output shaft. runs down the side of the crank case. i don't think it's chain lube cuz i don't. any ideas??
Somtimes it sucks not being in the loop. HUH??
Old 05-03-2010, 10:26 PM
I think that Badtraindriver had the exact same issue once, just can't remember what/where his was actually leaking. Looked like it was leaking in once place, where it was actually leaking somewhere else and the oil was collecting where it looked like it was leaking. Confused yet......
BRIAN
2008 WR250R 2006 DL1000
Old 05-03-2010, 11:37 PM
There is a round cover(with the hex shape) to the side cover that doesn't have a great seal. Oil can seap out over time. People advise that you can try different O-rings or use a sealant there to stop the leak. I was also advised that you can take the smaller cover off without the oil running out as the sump is lower, etc. if you want to make the adjustment right away.
-Brian
80 Honda CM400E
95 GSXR750W
06 DL1000
09 DRZ400S
Old 05-07-2010, 09:42 PM
PhotoBiker's Avatar
Wow, this is NOT what I thought this thread was about.
-=Glen=-
(n1xf)
'10 R1200GS
'02 DL1000
'06 KLX250S
Check out my Photo A Day Gallery or my Flickr Photostream
Old 05-27-2010, 10:50 AM
Casper's Avatar
www.ohioriders.net
Old 05-27-2010, 07:16 PM
Any solution to your problem yet. I have a similar issue. Think it may be the clutch push rod seal, but I want more possibilties to explore.
Old 05-27-2010, 09:05 PM
Dorzok's Avatar
haven't even looked at it yet. got a flat and been too busy to get it fixed so i haven't been riding and just plain forgot about it.
Old 09-21-2010, 10:21 PM
Dorzok's Avatar
went to replace the clutch rod seal. who put a metal retainer in there and then made me bend it all up trying to get the seal out?
looked at online micro-fish and could tell what part it is. please tell me that i don't have to take off the counter sprocket to get the retainer off.
Old 09-21-2010, 10:31 PM
PhotoBiker's Avatar
Do you mean part #34 below:
(This is for a 2002 DL1000) Found it in the "Transmission" Page out at Alpha Sports.
34 24751-06G00
RETAINER, DRIVE SHAFT
-=Glen=-
(n1xf)
'10 R1200GS
'02 DL1000
'06 KLX250S
Old 09-21-2010, 10:32 PM
dancer's Avatar
Cowboys aint easy to love
... please tell me that i don't have to take off the counter sprocket to get the retainer off.
Too late ...
DL1000K6 Red I believe in ... gravity!
"Everyone brings something to the party."
- Snoopy
