I have a '05 100 w/ 1700 miles. I have done a TBS and and checked the TPS. I programmed the PC3 to 1 bar above the mid level in the low range and 3 bars above the the mid level in the mid range. It idles at 1200 rpm. The bike runs good but I have noticed when bike is idling or after shutting it off, it smells like it's running rich. It has the stock air filter and it's not dirty.
| Sponsored Links | ||
Advertisement | ||
#2
Do you have a different exhaust?
Really...what you need 2 do is set the PC3 to the factory settings...then contact Jamie at Fuelmoto.com for a map specifically for the mods you're running. He has everything from stock...to modified exhaust/ air filter. BTD. |
#3
Stock exhaust. |
#4
Give Jamie a shout.
Even if you didn't buy from him...he'll more than likely help you out. Take his advice 100%...he knows his stuff about PowerCommanders!!! BTD. |
#5
In case someone didn't look on google it is actually:
http://www.fuelmotousa.com/ Dave in Dusty Doha, Qatar |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
