Fuel Injection Error - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 01-21-2010, 01:11 PM
rojobo's Avatar
Default Fuel Injection Error
Just to be sure if this is a problem.
Sometimes when I want to start my bike the FI light comes on and the fuel pump shuts off.
Just a simple on and off with the kill switch cures the problem and the bike is starting fine.
I this something to worry about or normal behavior ?
There are no error codes displayed.
Thanks
Live every day as if it would be your last because someday you're gonna be right !
Old 01-21-2010, 01:30 PM
Moderator++
That is not normal if the kill switch is in the run position to begin with. The switch contacts may be dirty. The FI stands for fault indication, not fuel injection.
Old 01-21-2010, 06:02 PM
bwringer's Avatar
You might also check the kickstand switch for filth leading to intermittent tendencies.
DAMHIK.
2005 KLR650, Aztec Red - Turd II, the ReTurdening
Old 01-21-2010, 06:07 PM
Moderator++
Cycling the kill switch would have no effect on the side stand switch though.
Old 01-22-2010, 09:39 AM
rojobo's Avatar
Thanks, Do you think that it could be the kill switch? What's the easiest way to clean it.
Do you have to open in order to be cleaned or can I simply spray some contact cleaner in the switch?
Old 01-22-2010, 09:44 AM
Moderator++
It could be the kill switch. I would want to look at the contacts to see if they look dirty but spraying contact cleaner inside the housing could do the trick.
Old 02-21-2010, 05:04 PM
MotoYeti's Avatar
I'm having the same problem on my 2002. Sometimes it starts up with no problems, other times it takes many flips of the kill-switch or twists of the ignition key. Started as an occasional occurrence a couple months ago and is now daily.
"FI" means "fault indicated"...meaning a generic electrical fault, or what? Where is that pointing to?
Old 02-21-2010, 08:36 PM
Moderator++
See http://www.vstrom.info/Smf/index.php/topic,7061.0.html for dealer mode and error codes on FI problems.
Old 02-21-2010, 08:58 PM
ozart's Avatar
My preferred method is to always disassemble and clean/fix. There's a chance spraying cleaner inside the housing will not even reach the required area. If you decide to do it this way though, make sure to use a contact cleaner that's safe for plastic like LPS, or it'll do more bad than good.
Old 02-22-2010, 09:33 AM
Heavy's Avatar
Next time it happens, leave the ignition on, get your spare key to lift the seat and put it in dealer mode. You'll probably find the fault code then.
DL1000K6
