#11
2 things.
1. You should include your bikes setup, K&N, Exhaust, etc.... 2. Also, do the maps work the same no matter which year they were made for? |
| Sponsored Links | ||
Advertisement | ||
#12
I am pretty darn happy with the stock PCIII map for my Stock 05 with secondaries removed and a fresh TBS.
I was using Cheff's fuelmoto average map and it worked well when the TBS was all screwed up. I tried it with a fresh TBS and secondaries removed and it had a funny little miss from about the low 3K's WOT to about 4k. So I went to the stock PCIII map and it's much improved overall. I do get (any advise would be greatly appreciated), a phenomenon now where I accelerate WOT out of about 3200 RPM but as it approaches the low 4's if I let off on the throttle it practically leaps forward - like it is getting either too much or not enough fuel at WOT and hits a sweet spot with a throttle position about 50-70%. Still all-in-all damn good map and so smooth and no bad manners whatsoever. You would think you are riding a wee-with some ass-kicking power on tap. The wee will make you grin...... The vee will make you laugh out loud.....
Chuck 05 DL-1000 - A farkling project in the making.... "A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government.” – George Washington |
#13
Ok guys, here are some more maps....
First one is the newest version of my custom map. If you are using my original map, please try this one. It has all the performance with less of the richness. I have found that this map seems to work really well on very lean, 02-03's - especially with aftermarket exhaust and 2ndaries removed. If you have a stock 02-03, this map will be rich and I can adjust it for you if so desired! I am posting in both .map and .djm files so you can use whichever version PCIII you like. Next up, we have a custom map that I modified for Big B when I was up at his place in OH. It's set up for an 04-05, with aftermarket exhaust and 2ndaries removed. It is in .djm format only, if someone needs it in .map format just let me know. Finally, we have a most excellent map created by Criscokid. BadTrainDriver is running this with great success, as are many other Strommers. This map seems to work very well with aftermarket exhaust and 2ndaries removed as well (can you see a trend here? What I have found, in my travels and adventures in PCIII mapping, is there seems to be 3 "basic" types of FI programming coming from Suzuki. They are:
m311-MG_V2.zip m311-BigB_v2.zip CiscoSummer.zip
![]() V-Strom - embarrassing squids since 2002. DL1000K2 #938 Blue, of course!! R.I.P Jason. You will be missed. Last edited by MonkeyGrass; 07-18-2007 at 06:42 PM. |
#14
Stromprofessor MonkeyGrass from MonkeyWorks at work:
#15
What is THAT on his head???????
BRIAN 2008 WR250R 2008 CONCOURS 1400 "Dearly departed 2005 DL1000"
#16
After Sunday, I should be on the most list, after master Big B dose his magic.
______ Kyle
2005 Black Vee
#17
I think a squirrel must have crawled up there and died!
![]() V-Strom - embarrassing squids since 2002. DL1000K2 #938 Blue, of course!! R.I.P Jason. You will be missed. |
#18
I have two newer maps that seem to be more stable at low rpm, curing the occasional sputter and hiccup at low rpm in warmer temps, yet leaner on the mid and upper end for economy. I just recently got 50mpg on a spirited 300 mile ride in the mountains (5,000ft) My "10-3-06" map works great for a lot of Strommers but is just a little to lean on the low end and I've heard reports of the occasional sputter using this map. I've since improved the map (I think? (by the way it's criscokid not ciscokid
'03 Vstrom - 996 - (3,318 miles and counting) OEM luggage, Zero Gravity windscreen, Two Brothers Titanium exhaust, PCIII '05 Vstrom - 996 - (death by rock) Suzuki heated Grips, Suzuki centerstand, PCIII '83 Honda Shadow 750 (sold) "Only two defining forces have ever offered to die for you: 1. Jesus Christ. 2. The American G.I. One died for your soul, the other for your freedom." |
#19
Please do post them up. BadTrainDriver and I had FITS trying to reformat that webpage that RenoJohn posted you map on... We ended up having to redo every single cell, digit by digit. Posting your excellent maps in .djm format would be of great assistance!
Oh, and I corrected my posts!! Sorry, I had your name misspelled. All fixed now.
#20
MG, I have attached two maps. I hope this works. I haven't attached maps before and figured out that I can't attach the .djm format so I zip'ed them. Here it goes.
-Chris
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
