How do I get stuff form easternbeaver - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > Regional or "club" sections > Australia-New Zealand
Australia-New Zealand Forum for the Stromtoopers Down Under
Old 01-07-2013, 03:40 AM
Default How do I get stuff form easternbeaver
Tried to order a Abs switch from EB and the shipping was like $ 800 for a small bit of wire .? Has enemy body got stuff from there befor and how !
Old 01-07-2013, 03:54 AM
BB63's Avatar
I have bought heaps of stuff from him, with quite reasonable shipping costs.
Cheers brian
Edit, maybe email him as it is probably a auto thingie doing the calcs for the shipping, or maybe there is a minimum amount, but I am sure there will be a way.
Old 01-07-2013, 04:20 AM
K1W1's Avatar
There is something wrong there. Whenever I have purchased things the freight has been very reasonable it's coming from Japan not the USA.
Send and email as suggested.
BTW. I just put an ABS switch in my basket and the freight was $7.95
Old 01-07-2013, 04:48 AM
Minimum order is $20 , he does that to discourage stupidity. Just pack it out with Posi-lock connectors or the plastic panel connectors.
Note, you need the wiring PLUS a 15A switch (not that easy to find), which comes to $30 something anyway.
Pete
Old 01-07-2013, 05:08 AM
I haven't done so, but is the light wiring loom a suggested item via the forum-I have seen some nasty consequences re pics,and which item do I need to order for a 08-thanks in advance.
Old 01-07-2013, 09:14 AM
Moderator++
See VStrom for the headlight relay kit. The high shipping cost only shows up if the minimum order is not met.
Old 01-07-2013, 07:42 PM
Thanks guys. Yes my order was only about $17 so that must have been the problem ,
Old 01-07-2013, 09:23 PM
herdygerdy's Avatar
I just ordered my PC-8, headlight relays and some Posilocks from EB today Tue 08JAN13, so will let you know when they arrive to give you an idea of delivery time, expecting it to be a bit slower after the Silly Season.
Cheers...Tony
Old 01-07-2013, 09:42 PM
K1W1's Avatar
Cheers...Tony
Delivery depends on what Jim is doing and what he has made up. If he is around and the stuff is available you will have it within a week. If he is busy or out of stock of something he needs to make up a part then it will take as long as it takes. He has always sent emails confirming dispatch when I have purchased so until you get an email assume that nothing has happened at his end.
Old 01-15-2013, 04:10 AM
herdygerdy's Avatar
Cheers...Tony
And today, just one week from ordering, it all arrived at home in Inner West, Sydney. Am one happy camper.
Cheers..Tony
