Rjays Super Topbox Mounting - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Australia-New Zealand Forum for the Stromtroopers Down Under
post #11 of 12 Old 04-14-2013, 09:33 AM
ockerstrom's Avatar
Originally Posted by herdygerdy View Post
If anyone needs a spare OEM Strom aluminium carrier rack as they work on their top box mountings, I have one available if needed.
I recall it is off a Vee, not sure if it will also fit a Wee.
Don't want a whole lot of $ for it, and would just like to see it put to good use by someone who needs one.
Cheers..Tony
Can't fit it on with the Happy Trails rack set up, but I could use a muffler heat shield for the stock muffler.
Ock. in Oz
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #12 of 12 Old 04-15-2013, 06:31 AM
Noelimits's Avatar
Here is a picture of how I attached the mounting plate to my bike. ImageUploadedByMO Free1366016872.443770.jpg
I took of the rack, removed the rubber and marked and drilled the mounting plate to line up with the holes in the rack where the plugs from the mat used to go. I then used the nuts bolts and rectangular washers that came with the Top box to bolt it on, loosely at first so that I could still get a spanner in to bolt the rack back on to the bike and then tightened the mounting plate down onto the rack, I would like to replace the bolts with some made from stainless steal and when I do that I will put some kind off packing between the rack and the plate to allow me to tighten the bolts up with out risk of distorting the mounting plate.
I hope this helps.
Suzuki GB Sports screen
OEM Knuckle Guards
Rjays Top Box
Noelimits is offline
Human Verification
